Results 1 to 7 of 7
Thread: running cat6s inside plastic conduit with 120v
    DIY Junior Member cmozment's Avatar
    Feb 2011
    Tuscaloosa, AL
    Default running cat6s inside plastic conduit with 120v
    I have an underground (in concrete) 1" grey PVC line that runs about 30 feet. After it runs under the concrete and up the wall into my drop in ceiling it connects to a metal conduit box that then runs to my panel.
    The PVC line has three 12ga insulated solid copper lines (black, white and green) for power to a computer in our sales area. Is there any way to run a network line (cat 5 or prefer cat6 sheilded) in the same PVC as the 120v.
    I read somewhere that it could be done but I would need to attach the shielding from the cat 6 to the same ground as the power to keep the interference at bay. I could do this by running the wire in the PVC and then attaching the sheilding to the metal box in the ceiling.
    I want this to be safe, but it would be very expensive to tear up the concrete-marble etc to have a second run of conduit.
    Any thoughts or comments much appreciated.
    Feb 2011
    NW Ontario, Canada
    I would run outdoor gel filled rodent resist and ground the rodent metal shield. I buy mine from Anixter.
    SUPERIOR C 04-003-55
    24-4P OUTSIDE PLANT CABL CAT5E
    DOUBLE JACKET FILLED CABLE
    BURIAL RODENT RESIST
    Jun 2007
    North Carolina
    No. It would need to have the same insulation rating as the line voltage in order to share the same raceway
    DIY Senior Member thassler's Avatar
    Dec 2006
    Tennessee
    Belden makes a Cat5e wire that is 600V AWM-rated. I've been allowed to run that in the same conduit as line voltage in the past. Never over 3ft however. Running data wire parallel with line voltage for 30ft is not a good idea even if it is shielded. In situations like that I've run fiber optic and used fiber transcievers to convert the mediums.
    TreyH
    ** Not a professional - only a DIYr **
    Feb 2011
    NW Ontario, Canada
    You could always run the ethernet over the power lines.
    http://www.netgear.com/home/products...e/XAV5001.aspx
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by thassler View Post
    In situations like that I've run fiber optic...
    Only problem... I don't think the OP would fit pre-connectorized fibre through the 1" conduit. He could cut it and then rent a fusion splicer or send me return airfare and I'll bring mine.
    DIY Junior Member david_griffin's Avatar
    Feb 2011
    Denver, CO
    This is always a risky business to put power cables in parallel with almost not insulated cables. I would avoid it.
  1. Aluminum wire and plastic conduit or copper and metal?
    By leejosepho in forum Electrical Forum discussion & Blog
    Last Post: 03-10-2013, 03:34 PM
  2. Running two power cables in same conduit
    By yaserhassan in forum Electrical Forum discussion & Blog
    Last Post: 10-21-2009, 02:32 PM
  3. MN-B, 12-3/GRD inside 2" PVC conduit
    By Ford2001 in forum Electrical Forum discussion & Blog
    Last Post: 09-21-2009, 07:28 PM
  4. Can overhead service wire be run inside conduit?
    Last Post: 10-15-2008, 05:12 PM
  5. Running a ground wire in conduit to plumbing
    By Juan for the road in forum Electrical Forum discussion & Blog
    Last Post: 08-16-2008, 03:06 AM
