Originally Posted by
Akpsdvan
Was brine removed from the brine tank?
Was salt used?
There are a few reasons why no soft water, bypass not right, a seal in the seal pack assembly out of position and letting untreated cross into the treated side, and the distributor tube out of the valve body and there letting water cross.
The later most likely will have some resin either in the drain or into the house lines.
A car going down the road with a blue cloud is because of a ring that is bad? true or false?
Same thing for the main seal pack and piston assembly.
