Results 1 to 3 of 3
Thread: Where to get European style rear spigot toilet?
    DIY Member Alan Muller's Avatar
    Oct 2009
    Delaware
    Default Where to get European style rear spigot toilet?
    I'm thinking of the style with a 4" rear spigot outlet about 7" (centerline) above the floor. This seems a logical approach to a job where it would be a lot easier not to have to go into the floor.
    Has anyone used these? Experiences? Where to get one?
    The only common source in the US seems to be Sani Flow, which uses them with their macerator pumps for pump-up applications.
    Thanks.
    Gerberit makes an in-wall setup for wall hung toilets. It's made in Europe and imported here.
    It works with Porcher, Duravit and Toto bowls.
    You have to differentiate between a rear outlet toilet which sits on the floor and one that hangs on the wall, ( I have never heard either one referred to as European style, however). Many manufacturers make both styles. Kohler's rear outlet floor mount is a Barrington. The wall hung models require a carrier inside the wall secured to the building's structure.
  1. Spigot Supply Valve - Pipe to outside spigot
    By drjimmy in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-26-2009, 05:03 PM
  2. Old Fashioned Rasied tank style toilet
    By Larry4 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-19-2007, 07:06 AM
  3. Rear Flush Toilet
    By mtnbiker3000 in forum Toilet Forum discussions
    Last Post: 11-26-2006, 05:58 AM
  4. rear exit toilet
    By indyjps in forum Toilet Forum discussions
    Last Post: 09-30-2006, 06:37 PM
  5. Help With European Tap Thread Sizes
    By wyeme in forum Shower & bathtub Forum & Blog
    Last Post: 09-01-2005, 06:33 AM
