Results 1 to 6 of 6
Thread: Pump cycling
    DIY Junior Member motovet123's Avatar
    Feb 2011
    virginia
    Default Pump cycling
    4 years a go i replaced my 1/2 hp shallow well ( 65 feet ) pump with a 3/4 hp ( it was only thing available on a Sunday evening.. I also replaced my expansion tank at the same time. Recently my bladder ruptured so i replaced the tank AND switch. New tank is a 44 gallon switch is a 30/60. My empty tank pressure was set to -2 llb's below the total pressure. Approx 37 psi according to the instructions. With that being said,,, my pump cycles with only a toilet flush. Could i have reversed the wires on the switch?
    Help!
    The air pressure with no water in the tank should be 1-2 psi less than the turn the pump on switch setting; 29-28 psi if you run 30/60.
    Feb 2011
    virginia
    Whoops, i made a typo... I meant to say 27 psi with the tank empty.
    Well Drilling/Service justwater's Avatar
    May 2010
    NE FL, SE GA
    well, unless your toilet uses 15 gallons when it flushes... you got something else going on.
    Nov 2010
    Maine
    Is there a check valve on the inlet line to the tank?
    Feb 2011
    virginia
    I don't think there is a check valve..... I'll check tomorrow when i get home.
  1. Jet pump to Fertilizer Injector-Pump Cycling Issue
    By orchidherder in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-31-2010, 01:50 PM
  2. spa pump cycling off and on
    By hockeydad in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-05-2009, 11:24 AM
  3. Pump Cycling
    By RayRay in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-08-2008, 05:50 AM
  4. Well Pump Cycling
    By chris_dale in forum Pumps and Tanks Well Forum & Blog
    Last Post: 11-10-2007, 07:17 AM
  5. Yet another self cycling pump
    By fohrman in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-02-2007, 12:00 PM
