Designie
I just purchased a new vanity and sink combo and bought a chrome steel pop up drain assembly to go with it.
Do I need plumber's putty under the drain flange of the pop up in the sink?
The reason I ask is that under the flange of the pop-up is a cutout in the drain pipe, and there is an area under the sink bowl where the overflow hole comes in. Below that, the drain pipe is clamped to the bottom of the sink with a rubber washer and the locknut. Also the hole in the sink doesn't mate well with the pop-up flange, unlike a kitchen sink strainer.
It seems like because the area below the pop-up drains water as well, that the flange is not intended to have putty. Am I correct?
