Green Genie
I'm renovating an upstairs bathroom and have stripped out the builder grade 60x30 steel tub and removed the alcove tiled area down to the studs. The tub was sitting on 5/8 ply subfloor and the finished floor is 3/8 sanded ply underlay and sheet vinyl butted up against the tub skirt.
My plan for the floor is to remove the sheet vinyl, install ditra and 3/8 porcelain floor tile. I'm still in the planning/purchasing materials process.
This might sound like a dumb question, (I was told there are no dumb questions only dumb answers) but to establish my flooring and plumbing elevations, would you install the tub on the 5/8 subfloor then tile up to the side of the skirt or have the floor finished then install the tub on top of the tile? What are the advantages/disadvantages of each install sequence?
Thanks for your help!
Dan
Go Canucks
Dan
Go Canucks
