It is time to retire that dinosaur. The efficiency is probably in the 50% range. I would not go very high efficiency if it is not your primary heat source. Maybe an 85 - 88% efficient cast iron boiler. The key to maximize fuel savings is properly size the new boiler. Heat loss not connected load. The amount and type of radiation has no bearing on the size of the new boiler.
