I never thought this could be so complicated. My requirements for a replacement toilet are ADA and a 14" rough in. What are my options??
Are you asking what model toilet will work for you? I would expect that any ADA compliant toilet should fit in a 14" rough in. There are many ADA compliant toilets to choose from.
it's the 14 " rough I'm having trouble with
I believe if you were to change the flange to an adjustable one, you could "lose" 2" and use a regular ADA toilet such as the Toto Drake. Often these flanges are offered as a way to gain 2" from a 10" rough-in to a 12", so I think they should work the other way. If this is not correct, I'm sure I will be corrected.
The Drake ADA doesn't adjust, it's a standard 12" rough toilet.
Most 14" toilet combinations are really 12" bowls with thicker tanks.
As long as there is room, using a standard 12" would be fine.
If you want to pull the bowl back toward the wall, then there are models that use a Unifit, some are for the 14" rough.
Toto Llyod has a 16.125" bowl height and the 14" unifit can be ordered for it.
Toto Nexus is 16.125" bowl and will work with a unifit.
Thanks for setting me straight. As you could probably tell from my post, I wasn't absolutely sure. It appears that there are easier ways that changing the flange to get around the problem anyway.
