Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
Thread: Help finding a fleck 5600 Piston
  1. #16
    Dec 2009
    Alaska
    That one sure looks like it with the way the piston looks..
    The piston that came out of the valve like yours is a little different from standard 5600, and the cap is more like the 6700 up flow valve.
    Your valve is likely to be an up flow brine , used as a filter set up by the company that did the spin on your system.
  2. #17
    Quote Originally Posted by Akpsdvan View Post
    Yeah and the green on the bottom of the piston matches the green in my existing one. theres another thread I did where you can see the base of the piston and it;s green
  3. #18
    Dec 2009
    Alaska
    It is not so much the color as it is the cuts or shape of the piston, where the indents are at and where the large parts are at.
    Have you had your piston out?
  4. #19
    no. I wanted a replacement on me.
  5. #20
    Dec 2009
    Alaska
    From what I was seeing in the photos and the that I would not use again but came out that one that valve that I have, it should work, has the same look to the piston and the same key at the top of the shaft ..
    As for the seal/spacer kit.... same as any 5600........ 60125 is the number that I have for the fleck sea/spacer kit.
  6. #21
    I cant understand the first part of your message. Too much wisky on a cold Alaska night?
  7. #22
    Dec 2009
    Alaska
    No wisky, it did get cold last night, -15 at my place.
    I looked at the photo in the link that you posted... the piston looks to be the same body as to the used one that I have in my hands.
    The link at the top of the piston the part that is bracketed by the white plastic is the same with the same hook in the open part with in the metal.
  8. #23
    got it thanks.
    So for the record the Fleck part number for the piston is 60102-52
  1. Fleck 5600 Econominder
    By brew24 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 05-26-2011, 09:14 PM
  2. Fleck 5600
    By CD King in forum Water Softener Forum, problems, installation and reviews
    Last Post: 09-14-2009, 07:47 PM
  3. Fleck 5600 or 5600SE
    By whatnow53548 in forum Plumbing Forum Discussion & Blog
    Last Post: 02-21-2008, 08:52 AM
  4. Fleck 5600
    By jjamison in forum Plumbing Forum Discussion & Blog
    Last Post: 11-08-2007, 04:53 PM
  5. 5600 Piston Assembly
    By captwally in forum Plumbing Forum Discussion & Blog
    Last Post: 07-10-2005, 07:28 PM
