Results 1 to 7 of 7
Thread: hot water temp loss when I pull up the shower diverter
Hybrid View
    DIY Junior Member forbins's Avatar
    Feb 2011
    Marshall, NC
    Default hot water temp loss when I pull up the shower diverter
    hey all, new the board, please help me if you can
    i'm a jack of all trades master of none kinda guy, i've installed a Bosch Aquastar 125 in my house. We have a small house, only one bathroom. The unit seems to be working great. The kitchen sink, bathroom sink, washing machine and bathtub all get really hot. The problem is when I pull up the show diverter on the bathtub spicket. As soon as I pull it up I can visibly see the flame go down on my tankless unit and the end result is a luke warm shower. I can get it flame up and produce hot water again if I turn on the bathroom sink while the shower is running. Also don't if it's related, but if i have the hot water on in the bathroom sink on and my wife turns on the hot water in the kitchen sink there is significant pressure loss.
    i've been reading about thermostatic shower valves vs pressure balance valves.
    please help, haven't had a decent shower in a while!!!
    All tankless use a system to detect flow, and only turn on when that flow exceeds a certain value (differs by brand and model). You may have a super saver showerhead, or you like it cool, because it sounds like you aren't getting the flow needed to keep the thing turned on. That's why, when you also turn on a sink, the increased flow triggers it to turn on. You might try a different showerhead.
    A thermostatically controlled shower valve is nice, but it can't magically generate hot water...if it isn't coming in, it can't adjust. But, if the temp varies while the shower is going on, it will try.
    Also note that many tankless systems have a flow restrictor in them, and this can mess up both pressure balanced and thermostatically controlled valves. Read the info carefully, and check with the manufacturer before investing in making a change.
    DIY Junior Member Henryj's Avatar
    Feb 2011
    Maryland
    Default Water flow
    Quote Originally Posted by forbins View Post
    Just change the shower head for one with higher flow, water flow is not sufficient to activate flow switch in water heater.
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by Henryj View Post
    Before you run out and buy another shower head, take off the existing head and test it with just the stub pipe to see how much flow there is. Some of the newer valve assemblies put a restriction on the shower line to ensure enough back pressure for the anti-scalding pressure balancing to work well.
    Inspect the inside of the shower head thread fitting. Some place a restrictor there that may be removed or drilled larger.
    Journeyman/Inspector Inspektor Ludwig's Avatar
    May 2006
    In the good ol' UPC
    I'll bet that tank is undersized.
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by Inspektor Ludwig View Post
    I know, it's a tankless job. :P
    Plumber Winslow's Avatar
    Dec 2005
    Hawaii
    Had that problem often with the old Price Pfister 2 handle valves. Remove the restrictor on the shower head. Or buy a new shower head and remove the restrictor before installing it.
  1. How to Replace a Delta Pull Down Diverter Tub Spout.
    By Jerry407 in forum Shower & bathtub Forum & Blog
    Last Post: 08-09-2010, 09:22 AM
  2. Loss in Shower Water Pressure
    By orlimar105 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-01-2009, 12:00 PM
  3. Check valve for temp. fix of pressure loss...
    By Nozaki in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-09-2008, 06:02 AM
  4. HELP - My Shower Water Temp & Pressure....
    By bob_aples in forum Shower & bathtub Forum & Blog
    Last Post: 05-22-2006, 01:20 PM
  5. Loss of Water Pressure in New Shower Install
    By parsonsv@yahoo.com in forum Shower & bathtub Forum & Blog
    Last Post: 11-09-2004, 12:03 PM
