Results 1 to 5 of 5
Thread: Copper pipe through concrete foundation
    DIY Junior Member tedf's Avatar
    Nov 2009
    Seattle
    Default Copper pipe through concrete foundation
    It is my understanding that a copper water supply line coming through a concrete foundation should not be in contact with the concrete. But what sort of sleeve or buffer should be used? Iíve seen black plumbing tape, closed-cell pipe insulation and spray foam sealant recommended. Is one of these the best choice - or something else?
    One who lurks Basement_Lurker's Avatar
    Jun 2007
    Victoria, BC
    You need something rigid enough to stand up to the wet concrete. Your best/easiest bet is to wrap your risers in foam...they sell foam insulation tubes which would work well for this, or you could just cut pvc risers and shove them deep into the dirt to make your seal.
    Broken promises don't upset me. I just think, why did they believe me? -Jack Handy
    www.blackbirdkitchenandbath.com
    Are you talking about the "foundation" or the "floor slab". They are two different situations and require different solutions, since a pipe through the foundation usually has to have provision to be sealed water tight.
    If going through the foundation, we have used pvc pipe to sleeve it. If coming through a slab, we have used foam and roof felt.
    Plumbing Solutions, LLC
    Your Local Plumber in Columbia, S.C.
    Through the slab, we either use Armorflex insulation or the vinyl sleeving.
  1. Use concrete floor paint on foundation?
    By dabiz7 in forum Remodel Forum & Blog
    Last Post: 10-07-2009, 02:11 PM
  2. Can my contractor drill through a concrete foundation beam?
    By staci in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-22-2009, 05:47 AM
  3. concrete foundation hole? where are the pipes?
    By stephaniesuer in forum Shower & bathtub Forum & Blog
    Last Post: 08-08-2006, 03:54 PM
  4. Tying concrete sidewalk into foundation
    By Lakee911 in forum Remodel Forum & Blog
    Last Post: 04-14-2006, 11:19 AM
  5. Hole through poured concrete foundation
    By jadnashua in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-22-2006, 01:45 PM
