Results 1 to 7 of 7
Thread: trap tailpiece minimum length
    DIY Junior Member stevenrobertburke's Avatar
    Feb 2011
    Olympic Valley, CA
    Default trap tailpiece minimum length
    Hi,
    What is the minimum trap-to-vertical waste drop for a 2" tailpience?
    We are in a tight situation for two separate situations. one situation is a shower drain, the other is a laundry drain. Both are 2" ABS and will be located in a crawlspace.i
    Thank you, Steve
    Plumber jimbo's Avatar
    I don't think there is any minimum. You could have the trap arm parallel to and in contact with the base of the shower, sink, etc.
    Feb 2011
    Olympic Valley, CA
    Thank you Jimbo,
    My intent is to avoid an "S trap" Is it ok to go from a 2" ABS trap to a 90 el (outlet is facting down) fitting into waste stack?
    Jan 2008
    The limiting is the distance from the trap to the vent.
    Jan 2006
    Rosedale, Md
    Quote Originally Posted by stevenrobertburke View Post
    Thank you Jimbo,
    If I read you correctly that IS a s-trap!
    quote; Is it ok to go from a 2" ABS trap to a 90 el (outlet is facting down) fitting into waste stack?
    That is the definition of an "S" trap, so you would be creating one, not avoiding it. And the way you describe it, there might also NOT be a vent for the drain.
    Under the UPC the developed length ( weir of trap to vent opening) minimum length = 2 X diameter.So your length can be quite short, provided it does not drop without a vent opening
  1. Tailpiece Trap Primer
    By dlarrivee in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-14-2011, 02:51 PM
  2. Minimum trap arm length?
    By mtbonn in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-19-2010, 07:45 AM
  3. P trap and tailpiece too close!
    By jdbangels in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-09-2010, 04:50 PM
  4. Trap arm height, minimum tail piece length
    By davefoc in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-18-2009, 09:20 AM
  5. Max length of a tailpiece?
    By jadnashua in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-16-2004, 10:19 AM
