Page 1 of 3 123 LastLast
Results 1 to 15 of 36
Thread: Floodchek washing machine hoses
    DIY Junior Member richard8's Avatar
    Oct 2008
    Washington
    Default Floodchek washing machine hoses
    Hello,
    Has anyone experienced or used floodchek washing machine hoses.
    Also, how do you like them.
    Thanks.
    http://www.floodchek.com/
    The Floodchek hoses are the best. Made from hydraulic hose.
    Not to be confused with Floodsafe, which I do not recommend.
    Engineer maddog's Avatar
    Aug 2006
    near San Jose, CA.
    Anybody seen a braided SS hose (other than Floodsafe) burst? I know the Floodsafe hoses had problems with bursting at the fitting ... but do the actual SS hoses fail? I had a standard rubber washer hose that grew a huge bubble (a flood waiting to happen) before switching to the braided SS hoses. They are about 10 years old and look fine - should I change them? Thanks.
    Oct 2008
    Washington
    Default washing machine hoses braided steel vs. rubber
    I have not heard of any instance of braided steel bursting. If there are any cases, please let me know.
    If there are any pictures, please post also. What was the time frame, burst after 13 years, 18 years.
    Or just create a blister, then small leak ????
    I have heard of rubber hoses bursting after 7 years, that is when the washing machine is turned on.
    I have also heard from plumbers that they recommend stainless steel.
    Feb 2011
    NW Ontario, Canada
    Of course braided steel hoses will only be as good as the barb fittings on the end. I looked over several brands before deciding. Don't recall the brand but they've been in service for 12 years.
    When I plumbed in my laundry room I also made sure to install large hammer stops at the washer taps.
    Something worth considering is an automatic water shutoff that only turns on the water when the washer is in use.
    http://www.watts.com/pages/_products...s.asp?pid=3427
    The Watts IntelliFlow™ Automatic No. 2 (A2C-M) is equipped with a state of the art electric current sensing device. When the washer is turned on, the device senses the current flow to the washer and opens the valves.
    I wouldn't trust a braided or a rubber hose past ten years.
    Plumber jimbo's Avatar
    What are those floodchek hoses made of that makes it that much better thatn ss braided? I think Fluidmaster has a lifetime warranty.
    Jul 2007
    USA
    One problem with the SS ones are they do not loop easily and mark the walls. I'm thinking the Floodchek might be a little easier in a confined space with six inches or so between the washer and the back wall.
    I do like the little 45º adapters. I have a stacker machine, and straight on is a little awkward, and the hoses you can get with 90's on them don't work at all,
    Jul 2007
    USA
    Thanks. Good tip.
    DIY Junior Member Brian.Hoard's Avatar
    Nov 2010
    Haymarket, VA
    Hi.
    I just read your PDF that recommended the FloodChek hoses ( http://www.terrylove.com/pdf/bottom_...ing_2011_2.pdf ) and I plan on ordering them for my laundry room remodel. I'm wondering since both the washing machine's water connections and the supplies coming from the wall are horizontal, should I add angled adapters to both ends of the hoses so they are pointing down? It seems to me like that would be less stress on the hoses. What's your advice?
    These whirlpool industrial grade hoses supposedly pass hot water burst test at >1500 PSI. http://www.appliancepartspros.com/pa...&pn_=8212487RP
    DIY Junior Member dayster's Avatar
    Jun 2007
    Vancouver, BC
    I find the Floodcheck website a bit odd. There is no mention whatsoever of the construction or design of their hoses, the site just says that the hoses are great... without explanation. Seems a bit suspect. The look nice though! Terry, howcum you like them so much?
    I like that since 1989 they haven't had a failure.
    And the 20 year warranty.
    I remember walking into a friends home this Summer with the standard hoses and seeing three inches of water in her basement.
    If you can imagine this, I pulled her toilet off and let the water in the basement drain down the closet flange.
    Dec 2009
    northfork, california
    Good information - All those so called SS wrapped supply lines from china should be suspect, because you really do not know what is inside - probably just a cheap vinyl tube.
    Its no mystery how to build a great hose. The best washer line would be a 3,000 or 4500 PSI hydraulic line. I have some on my excavator operating at 4500PSI for 15 years under incredible strain and shock inside and out. And you can have them made at any auto parts store in a minute- and quite flexible also.... Too bad they don't have garden hose ends for them!
    http://www.surpluscenter.com/sort.as...c&keyword=HHNB
    On edit, I think I really will use hydraulic hoses on the washer. Just add an adapter, have a 2950 PSI safety factor, and save a bit of money over the cost of the floodsafes.
    http://www.surpluscenter.com/item.as...name=hydraulic
    And here is a beauty for the dishwasher- 15 bucks and 12,000psi burst!
    Try and find that quality at home depression.
  1. New Washing Machine
    By Barneyn in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-20-2007, 12:07 PM
  2. washing machine adaptations
    By ELLETHEKITTY in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-11-2007, 07:25 AM
  3. Under counter washing machine
    By teeman11 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-19-2006, 08:47 AM
  4. Washing Machine Outlet Box
    By Plumbcatastrophe in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-16-2006, 05:58 AM
  5. Washing machine hoses
    By ally68 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-29-2005, 07:21 PM
