If it is "loose" it will flush out as soon as you use some water. If it is not, then it should not create a problem. You probably "smell" the carbon because you know it is there, and if you had not seen it would not know the difference. The "oxidation" was probably "water soluble" flux that you overheated, and if so there should have been very little "inside" the pipe.
