Thread: Septic system
    DIY JUNIOR MEMBER ANTMAL's Avatar
    Feb 2011
    UDORA, ONTARIO, CANADA
    Default Septic system
    I have A home out in the country. We have A septic system & have had very little problems with it . I have A water softner & A " Non Chemical Iron Eater" also .Both these systems regenerate and the water from the regeneration is directed into where my sump pump is . That water then pumped by my sump pump out onto the back lawn. My question is; can I have the water , instead of going into the area where the sump pump is, go into my septic system ?
    Thanks in advance
    Anthony
    Millions of people, including myself, do just that.
    Feb 2011
    Thank-you HJ. Would there be A problem with so much water going into the septic system ?.....i.e. the bacteria would diluted and would be inactive ?
    Thanks in advance
  1. Septic System questions
    By JAR8832 in forum Drain Cleaning
    Last Post: 09-22-2011, 05:25 AM
  2. New septic system.
    By Ringwood in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-24-2010, 01:58 PM
  3. Re-locating an Aerobic Septic Tank System or use system as-is?
    By pearlbluevtx in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-08-2010, 09:50 AM
  4. Starting up a septic system
    By got_nailed in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-31-2007, 09:08 AM
  5. Septic System
    By missy in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-25-2006, 04:07 PM
