It is because you are using A-lamps, not reflector lamps. A-lamps give out a tremendous amount of heat all around. Reflector lamps concentrate it downward.
Also, the trim has a lot to do with it. The actual lamp size and selection is based on the trim, not the can.
Also, if you do not even have the trims in yet this will affect the thermal sensor.
