coldntx
Hello...thanks is advance for anyone who can help point me in the right direction...
I live in an older house, with barely any insulation. I wrapped all of my exposed pipes, kept the taps dripping, left the cabinets open inside...pretty much everything they suggest on the news here when it reaches the 20s. Unfortunately in my garage ceiling coming from my water heater were uninsulated pipes that burst. They are 2 very small holes, I would say the size of a pencil eraser. I have galvanized pipes. The water is currently off and I drained the pipes via the faucets inside.
My question is: Is there anyone to plug the holes in a safe, actual way that will work and will not cause any more leaks? If so, how long do these methods last?
Also, once I fix it, how do I keep it from happening again. There is no access in the ceiling except the giant hole where you can just see a few feet of pipe.
Someone I know said I could buy this waterproof putty, let it cure, and put a pipe clamp on it and that it should last a year or so. I'm on a limited budget, so if I can do the job myself until I can afford new pipe and plumber it would be great. At the same time, if I have to use my credit card for a plumber I'd rather know before I buy everything to fix it.
Thank you!!
Thank you!!
