Results 1 to 3 of 3
Thread: Fleck 7000 Problem
Hybrid View
    DIY Junior Member ArayT's Avatar
    May 2009
    Middle Georgia
    Default Fleck 7000 Problem
    Got it fixed!! Idiot me mistook the PM light for the flow light.
    Need advise on programming valve. I Try to enter extended program mode (via v^ simu for 5 seconds at 12:01pm) the programming light comes on, I push the extra cycle botton and A-10 displays. The up and down allows me to changes this. Now the problem I push the extra cycle button again and it brings be right back to the time. It will not let me continue. Any advise would be appreciated.
    Thanks, Ray
    If you aren't locked out, and I don't know what you see if you are, then the circuit board would be bad IMO.
    Dec 2009
    Alaska
    Which control is it that you have?
    The first generation was red read outs, the second generation is of an LCD read out, black on a greenish background?
    Neither have a lock out ...
    It is possible that you have gotten in a loop of sorts and there is a way of a Master Reset to factory settings.. once that is done you would need to reprogram the settings for default days , backwash time and the rest of the settings that where set for your water and useage.
  1. Fleck 2510sxt - Problem with losing my settings over time
    By chargedmr2 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 04-03-2011, 10:20 AM
  2. Fleck 9100 Useage Mete Problem
    By Gerrylc in forum Water Softener Forum, problems, installation and reviews
    Last Post: 12-28-2010, 07:12 AM
  3. Help Programming a Fleck 7000 SXT
    By batboy in forum Water Softener Forum, problems, installation and reviews
    Last Post: 09-03-2010, 06:43 PM
  4. Fleck 5600 Valve Problem
    By filadajunk in forum Plumbing Forum Discussion & Blog
    Last Post: 12-17-2007, 09:52 PM
  5. fleck 7000 or clack ?? help
    By gerrythegreat in forum Pumps and Tanks Well Forum & Blog
    Last Post: 11-24-2006, 08:30 PM
