Results 1 to 4 of 4
Thread: Converting Light Fixture Box To Powered Outlet
    DIY Senior Member Kiko's Avatar
    Jul 2009
    Royal Oak, Michigan
    Default Converting Light Fixture Box To Powered Outlet
    What's the most elegant way of doing this, without replacing the round light box with a standard receptacle box? It's in a living room, so I really don't want to use one of those ugly, gray metal "work box" receptacle covers that the hardware stores recommend. After wiring in the receptacle, can I just screw the receptacle into the existing box and then screw a nice 5" round decorative outlet cover to the receptacle?
    If you can find a decorative round cover, it should be fine.
    You will probably need a "round grey work box plate" to adapt to the receptacle. Once that is done, you use any wall plate that covers the opening over the receptacle.
    Jul 2009
    Royal Oak, Michigan
    That's exactly what I ended up doing. Without the round gray workbox adapter, the receptacle doesn't screw in properly to the round light box. Then I searched all over for a very oversized single-gang outlet cover in white. I found one at an old, Ma and Pa hardware store near me.
  1. Light fixture for above a bathroom shower
    By steveb7az in forum Remodel Forum & Blog
    Last Post: 11-05-2010, 03:02 PM
  2. DIY - Split receptacle to light switch and light fixture with 14/2?
    By AJM in forum Electrical Forum discussion & Blog
    Last Post: 11-24-2009, 04:36 PM
  3. bathroom light fixture
    By rburt5 in forum Shower & bathtub Forum & Blog
    Last Post: 03-21-2009, 06:53 AM
  4. Light fixture above the shower
    By Dexter in forum Shower & bathtub Forum & Blog
    Last Post: 09-29-2008, 06:37 PM
  5. Ungrounded light fixture
    By maddfrog in forum Electrical Forum discussion & Blog
    Last Post: 12-01-2007, 11:51 AM
