Results 1 to 2 of 2
Thread: Jado three handle tub/shower setup options
    DIY Junior Member britr07's Avatar
    Jan 2011
    Baltimore, MD
    Default Jado three handle tub/shower setup options
    new to site. using jado 818 series. tiled wall finished for three handle tub/shower setup. contractor "plumber" used jado 4/3 diverter as center and hot and cold handles. works, but not ideal.
    anyone know of three handle valve body to use with jado 818 handles? any way to modify pricepfister three handle tub/shower valve body to make compatible with jado 818 handles.
    thanks, Troy
    Swapping handles from different brands is sort of like trying to put a Chevy engine in a Ford...while maybe possible, not likely without a lot of machining or other work. Also, if those handles are into straight valves, and this is a remodel, it would not pass code. All new/remodeled (not repaired) showers require anti-scald technology, and straight volume controls do NOT have this capability. An inspector would likely fail it, and if you aren't getting an inspection, you are at risk for other problems (financial and otherwise) when it comes time to sell, too.
    this should have been addressed before you tiled.
  1. Installing Moen single handle Posi-Temp setup
    By Nate R in forum Shower & bathtub Forum & Blog
    Last Post: 11-17-2012, 01:22 PM
  2. How do I handle this dishwasher drain setup?
    By TubeGuru in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-29-2010, 11:17 AM
  3. Shower handle and trim for 22 year old pull-out handle
    By Steveindanville in forum Shower & bathtub Forum & Blog
    Last Post: 12-23-2009, 10:27 AM
  4. Handle Replacement options
    By jerome8283 in forum Shower & bathtub Forum & Blog
    Last Post: 09-26-2008, 10:50 AM
  5. single-handle Aqualine shower handle
    By marchat in forum Shower & bathtub Forum & Blog
    Last Post: 12-29-2006, 02:18 PM
