Results 1 to 5 of 5
Thread: Is a flexible water and gas line to a water heater ok in Illinois?
    DIY Member paulsiu's Avatar
    Jun 2009
    Itasca, IL
    Default Is a flexible water and gas line to a water heater ok in Illinois?
    Hi
    I live in Itasca, IL a suburb west of Chicago. I attempt to look into the IL code, but could not find any reference to this. I have gas coming out of a black iron gas pipe and water coming out from copper pipe from the roof of the basement.
    My questions are:
    1. Am I allow to hook up the gas to the water heater using a short length of flexible gas line?
    2. Am I allow to hook up the water to the water heater using a short lengh of flexible water line?
    Thanks.
    Paul
    Plumber jimbo's Avatar
    Very wordy code....but it does contain provision that a town may issue a permit if "....the applicant is the owner occupant of a single family residence that is the subject of the permit.or that the applicant is the owner occupant of a single family residence that is the subject of the permit."
    In perusing the codes briefly, I could not answer the question about whether the code REQUIRES, ALLOWS, or PROHIBITS flexible connectore.
    I hope an IL plumber can help us with that.
    In CA, flex connecors on gas and water connections are REQUIRED.
    Nov 2008
    Chicago, IL
    In Illinois the water heater is required that the water pipes and gas to be hard piped. Also unions are required on the water piping. One more thing changing out a water heater requires a licensed plumber to do the job.
    Illinois must not be in earthquake country.
    Do you even have to strap your tanks?
    Or do you just worry about tornadoes taking the entire home away?
    Nov 2008
    Chicago, IL
    No straps required unless mounted on a stand in a garage. Tornadoes is our worry in the flat lands here.
  1. Shutoff Valve in Hot Water Line of Water Heater
    By aaronm in forum Water Heater Forum, Tanks
    Last Post: 05-23-2011, 05:29 PM
  2. Flexible supply lines on a gas water heater
    By Ian Gills in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-26-2010, 08:51 PM
  3. water heater hot water line shut off valve
    By astro46 in forum Water Heater Forum, Tanks
    Last Post: 06-09-2010, 07:01 PM
  4. Tapping into a flexible water line
    By cacherjoe in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-28-2009, 10:19 AM
  5. Hot water recirc line w/ instant water heater?
    By ffmedic7 in forum Tankless Water Heater Forum
    Last Post: 09-04-2006, 02:31 PM
