Results 1 to 2 of 2
Thread: Jacuzzi whirlpool bath
    DIY Junior Member GEAR's Avatar
    Jan 2011
    Fort Wayne, IN
    Default Jacuzzi whirlpool bath
    i am remodeling bathroom and need to remove and re-install jacuzzi whirlpool bath....does the drain spout from the tub just insert inside the house drain and need to be lifted out....or is there some kind of comnnection that holds the 2 together......
    The tub drain could be solvent welded to the rest of the drain, or it could have slip fittings, that would require you to loosen the nut. In either case, it should NOT just pull out. If solid welded, you'd have to cut the pipe. Otherwise, you could loosen the nut(s) and pull it apart.
  1. Whirlpool bath problem
    By vito in forum Shower & bathtub Forum & Blog
    Last Post: 05-16-2010, 03:34 PM
  2. Air bath whirlpool tubs????
    By edwardh1 in forum Shower & bathtub Forum & Blog
    Last Post: 07-09-2009, 04:49 PM
  3. Jacuzzi Brand Duetta Whirlpool Tub -- anyone have one?
    By WynsWrld98 in forum Shower & bathtub Forum & Blog
    Last Post: 03-26-2009, 04:23 PM
  4. Installing jacuzzi 6060 whirlpool bath
    By jjrausch in forum Shower & bathtub Forum & Blog
    Last Post: 06-04-2008, 05:07 AM
  5. Jacuzzi "Espree" corner whirlpool
    By hsullivan in forum Shower & bathtub Forum & Blog
    Last Post: 07-04-2005, 11:33 AM
