Results 1 to 5 of 5
Thread: How to extend a CO?
    DIY Senior Member DavidTu's Avatar
    Dec 2009
    Seattle, WA
    Default How to extend a CO?
    I have a 45-deg Wye with a CO glued on at bottom of a drop.... problem is a new wall was added behind CO that makes access difficult. What I want to do now is extend the CO back to the face of the wall so access will be from other side of the wall. Can I do this simply by screwing in a male threaded adapter into the CO and gluing pipe and new CO onto that?
    If that will do what you want, the yes, assuming it is NOT a 3 1/2" cast iron cleanout.
    DIY Junior Member dugfresh's Avatar
    Jan 2011
    Seattle, WA
    You will want to make sure that you use long turn radius fittings for any extension. Make sure also that the clean out at your final finished wall isn't tighter than the one that is buried.
    Dec 2009
    Seattle, WA
    No, but I do have another 3.5" CI CO elsewhere... I thought my building sewer CI pipe was 3" ... but I measured the floor CO to 3.5" as you suggest... does that mean my building sewer is really 3.5" or 4" or what? I sized my vents assuming it was 3"! Am I in trouble?!?
    Jan 2006
    Rosedale, Md
    Quote Originally Posted by DavidTu View Post
    Your building sewer can be either 3or 4in., the c.o.s were made in off breed sizes to stop people from attaching pipe to them
  1. Extend a shower drain with a snap-in strainer?
    By randini in forum Shower & bathtub Forum & Blog
    Last Post: 01-04-2011, 11:18 AM
  2. Cost to extend gas line in garage?
    By thinkly in forum HVAC Heating & Cooling
    Last Post: 10-05-2010, 11:26 AM
  3. Need to extend trap fitting
    By RoddyPiper in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-10-2008, 06:00 AM
  4. Ok to cut or extend closet bend?
    By peeks in forum Toilet Forum discussions
    Last Post: 07-06-2005, 10:11 AM
  5. Extend Shallow Water Pump
    By GAWEBA in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-08-2005, 10:07 AM
