Page 1 of 4 1234 LastLast
Results 1 to 15 of 54
Thread: No water out of faucets?
    DIY Member Iknownothing's Avatar
    Jan 2011
    Newcastle, ON
    Default No water out of faucets?
    Hello all, I am new her so I hope I make the right impression. I know nothing!!! No I'm joking, But I am a little lost here. I am on a well. Electric heater. Bladder tank. I needed to clean my salt reservoir and in doing so, I turn off the power to both the pump and heater. Drain the bladder, but the heater gave me problems. It wasn't flowing much at all. So I pulled on the release valve and to my surprise, water came gushing out of the bottom.
    I drain both tanks clean, and turn back my water pump, filled the bladder, then slowly opened the valve for the heater and she filled up nicely. Turned my heater power on. Now the final test... I go to turn on the faucet, nothing but a bit of water a gushing air. Cold water came out but very low pressure til there was nothing. Now I get nothing out of either faucets and theres water in the tanks. I am sure it's something I didn't do right but not sure. I didn't open a hot water faucet while draining the tanks. That I think may have been the issue. But now what do I do? Any help would be appreciated. Thanks a million.
    Well, hopefully, you turned the power off to the heater before you drained it, or else, you'll need to replace the heating elements, since they would very quickly burn out with no water around them to transfer it to. Did the pump come back on? When you say salt reservoir, are you talking a water softener? Draining things might have flushed stuff through the softener and plugged things up. You might try removing the aerators on the faucets and see if the water flows then. The softener might need some servicing if you've flushed all of the resin out and disrupted the gravel bed (if it has one). the toilet fill valves might be a pain to clean out, and for their cost, might be just easier to replace, if this is the situation. See what one of the pros has to say...
    Jan 2011
    Newcastle, ON
    No, I didn't disrupt the resin tank at all, and there's water in the heater and bladder but nothingis coming out of the faucets. I have no clue? The pressure cut of is at 65. Just a little bit of air comes out then stops, with no water? Please help.
    Jan 2011
    Newcastle, ON
    Need more info? I'll tell you everything I know!!!
    DIY Senior Member Hairyhosebib's Avatar
    Jun 2010
    Arizona
    Does your tub faucet work? Try removing the aerator from the faucets to see if they are all plugged with junk.
    Jan 2011
    Newcastle, ON
    Aerator? Haven't heard of that, how do you do that? Not the screen?
    Jan 2011
    Newcastle, ON
    No it's not that for sure. I'm on a well and tried t do the annual cleanup. And in refilling the bladder tank, I slowly release the valve and the water then goes through the softener, the ultraviolet light, then either to the faucet or hot water tank. But the hot water tank seems to be letting a little bit of water in at a time. Almost like a pressure problem.
    Water won't fill things until you open a faucet...open both hot and cold and let the water push the air out. Again, if the WH was turned on before it was filled with water (and it won't flow in there until you open a faucet to let out the trapped air), you've burned out the heating elements.
    Jan 2011
    Newcastle, ON
    Pm'd you. I have the faucet open but the WH doesn't seem to wanna fill?
    Jan 2011
    Newcastle, ON
    Please anyone, I am desprite for answers please. And Thanks
    Scotsman mcconnellplumbing's Avatar
    Dec 2010
    Wellston, OK
    OK, have you opened and left open the faucet on the hot side to allow trapped air out of the water heater and allow new incoming cold water to fill it?
    Jan 2011
    Newcastle, ON
    I did but nothing seems to be getting the water much passed the HW tank. I think there's a pressure issue.
    Jan 2011
    Newcastle, ON
    There's water in the bladder, 65 psi worth, it flows through the ultra violet but slowly if at all gets into the HW tank. So I've been waiting for it to fill, taps we're open but nothing really is coming out, sound or water. I'm lost. If there's pressure in the bladder tank, why can't it push throught the faucets?
    Dec 2010
    Wellston, OK
    It wasn't clear, do you have water pressure on cold but not hot, hot but not cold, or neither?
    Dec 2010
    Wellston, OK
    did you turn off the water to the water heater or just kill the electricity to the pump?
  1. Hot water in shower not turning on, all other faucets have hot and cold water
    By redrover in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-08-2011, 07:20 AM
  2. Lukewarm water all faucets
    By retired1 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-13-2009, 10:18 AM
  3. No water from outside faucets
    By rileydog88 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-07-2009, 06:12 PM
  4. No water to faucets
    By rockzo6 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-28-2009, 06:59 AM
  5. Air in water from faucets
    By ccsmith51 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-23-2008, 08:54 PM
