Results 1 to 4 of 4
Thread: Aquastat for Peerless Boiler
    DIY Junior Member
    Feb 2011
    United Kingdom
    Default Aquastat for Peerless Boiler
    I need to replace the aquastat on my 1980 peerless boiler. The description is: Honeywell R8182D 1012. Everywhere I have looked, and all the people I have talked with say this unit never existed with the 1012 extension. When I ask for a replacement, they say I can not get a replacement without a crossreference to the 1012, which they say doesnt exist. This is a catch 22.
    Nov 2010
    Maine
    The last four digits refer to the mounting position. You can use any 8182 that will fit the well.
    DIY Member tk03's Avatar
    Jan 2011
    Harrisburg, pa
    The 1020 is Honeywell's way to tell them how it was boxed or something special to a manufacturers spec. As Tom stated any R8182D will work. Forget the last 4 digits. The R8182D is a triple action aquastat that controls the burner and pump. It includes the primary control for the oil burner. All the newer stuff uses an aquastat and a separate oil burner primary control.
    Nov 2010
    Maine
    Indeed and if it were mine I would change out controls and use a L8124C and a separate primary control, either honeywell or Beckett. Less money
  1. Peerless Gas boiler - replacement burner tubes
    By BrianP in forum Boiler Forum
    Last Post: 01-10-2011, 02:01 PM
  2. Crown boiler aquastat
    By rotsa in forum HVAC Heating & Cooling
    Last Post: 01-04-2011, 10:13 AM
  3. Budarus or Peerless
    By derekgaddy in forum Boiler Forum
    Last Post: 03-18-2010, 05:49 AM
  4. aquastat setting and boiler question
    By bbillcee in forum Boiler Forum
    Last Post: 10-12-2009, 05:37 PM
  5. Fearless Peerless
    By Buster55 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-23-2007, 10:07 AM
