Results 1 to 2 of 2
Thread: tp discharge pipe
    DIY Junior Member reed50's Avatar
    Jul 2010
    tennessee
    Default tp discharge pipe
    Discovered the tp valve discharge pipe goes straight into the crawl space. I am going to fix that issue but had a question. The discharge pipe itself is cvpc pipe. The end screwed into the tp valve is also plastic. Is this correct or does it need to be changed. Thanks for the help.
    The discharge could be quite hot. Check local codes, but plastic pipe may not be allowed within a certain distance of the WH. I'd prefer copper. The local code also would dictate where it could discharge. It is better to have it discharge where you would notice it so you have a heads-up as to a problem, rather than it being hidden where you'd probably never know until it was a really big problem.
  1. how to pipe the sump discharge into street catchbasin
    By ct-esq in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-15-2009, 09:30 PM
  2. Discharge Pipe Into Cistern
    By Dungmin in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-19-2007, 07:17 AM
  3. Sump pump discharge pipe
    By bakechad in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-31-2006, 10:59 AM
  4. Sump Pump Discharge Pipe Length???
    By jac5099 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-24-2005, 11:26 AM
  5. Sump Pump discharge pipe air hole
    By bdlancaster in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-11-2004, 08:40 AM
