mccordski
Welding Engineer
My water supply line from the meter is 3/4" PVC, and I would like to plumb the house with PEX. The best idea I have is to transition to CPVC for the run through the wall, so I can use sharkbite fittings for the transition to PEX, and to add a sharkbite ball valve for a shut-off. The added consequence is another transition from PVC to CPVC, which I think I will use brass threaded adapters. It's not really clean or pretty, and uses a lot of different materials, I think it will work, any suggestions?
