Results 1 to 2 of 2
Thread: Moen Models? Posi-Temp
    DIY Junior Member dkdaniel's Avatar
    Jan 2011
    Iowa City IA
    Default Moen Models? Posi-Temp
    Hi All! I've been researching how to repair my Moen shower faucet. I've found many helpful online videos on fixing the Moen model 1220 or 1225. My problem is that my cartridge-based valve doesn't look like that. Mine does not pull out before it turns. It simply turns and mixes the water cold-to-hot as it travels thru its arc. Upon removing the handle, I see what is probably a cartridge covered with a white plastic/nylon part combined with a brass insert with a set screww that allows the mix ratio to be adjusted. What am I looking at here? I have not found any other Moen model online that looks like this. I'll appreciate the help as my water bill is up 50% because of the leak.
    Sounds like you have a positem. There are lots of trim varieties, but this diagram shows pretty much how it all goes together:
    http://www.moen.com/shared/pdf/l82691pt.pdf
    Remove the sleeve ("stop tube") and after turning off your main water, pull out the retaining clip. You will probably need a Moen cartridge puller, which is available at the same place you will buy the new 1222 cartridge
  1. Leaking Moen Positemp
    By 1guido in forum Shower & bathtub Forum & Blog
    Last Post: 06-13-2009, 09:10 AM
  2. Moen positemp problem - clogged??
    By kool_bean in forum Shower & bathtub Forum & Blog
    Last Post: 01-16-2009, 10:37 AM
  3. Best Toto Eco models
    By pottymouth in forum Toilet Forum discussions
    Last Post: 10-01-2008, 02:41 PM
  4. moentrol and positemp, same escutcheon?
    By cbl in forum Plumbing Forum Discussion & Blog
    Last Post: 04-25-2007, 03:48 PM
  5. Moen positemp debris clogs
    By jerryleesprague in forum Plumbing Forum Discussion & Blog
    Last Post: 04-20-2006, 07:18 PM
