Results 1 to 6 of 6
Thread: Good deal or continue shopping?
    DIY Junior Member asmart82's Avatar
    Jan 2011
    East Orlando FL
    Default Good deal or continue shopping?
    I had a gentleman come out today from a local water company. I've had really bad issues with black particles in my water. Bad enough that I can not wash my clothes. He did some tests and said my iron was not an issue but mentioned installing an iron filter. I want to say he recommended the iron filter because I had a high sulfur content but I'm not positive about that. Also, he did a test of my water for hardness and it took 15 drops of water for his test liquid to go from purple to blue. He said it typically should take around 10, so I have extremely hard water.
    Below are his recommendations. Any comments would be appreciated!
    New Technology Iron Filter with Manganese Green Sand Plus with a Chlorine Regenerate - $995 installed
    - I'm not sure if New Tech is the company or if he was referring to a new type of technology used
    Reconditioned Fleck 5600 water softner - $600 installed
    - He mentioned that he refurbishes system that he replaces and resells them for a cheaper price
    He said the above should solve my problems but if not, he also has a 20"x4" post filter he can install for $200.
    Does this sound like a good deal as far as pricing?
    I'm sure there is additional information that could be provided but feel free to ask questions as well.
    DIY Member JKERN's Avatar
    Jan 2011
    Artesia NM
    The black specs may also be manganese which could change sizing and filter run lengths depending on what he has bidded for your needs. When in doubt check it out. If this is a local dealer maybe you should get a second opinion. Reputable dealers should have no problem in giving you a free quote and if the general synopsis is the same amongst all of them as far as what you are needing then you can compare pricing after that. And you should always have a water analysis done you may contact a local university and some will do the testing for free.
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    What valve is he using for the greensand filter? I sell my greensand systems for $900.00 installed so the price sounds good. As for the used softener, I don't sell them but $600.00 is a good price. Is it a metered or timered unit? How long is the warranty? I tell my customers for another $300.00 you get a 5 year warranty. With both the iron filter and softener, you shouldn't need another filter.
    Jan 2011
    East Orlando FL
    Quote Originally Posted by mialynette2003 View Post
    These are Fleck 5600 metered valves on both. There was no mention of a warranty being offered for either the filter or the softner
    Dec 2009
    Alaska
    A metered 5600 on greensand would not be my first choice, I would rather have a 2510 day on it so that it cleans every x days and one can change the times with in the cleaning cycle.
    5600 standard does not have that , it is controled by a single 1/30 timer motor..
    Jan 2008
    Even if it sounded like a great deal, I would get a second opinion anyway.
    There are a lot of people out there interested in selling you something you might not need.
  1. Shopping for toilets
    By Dawn Kane in forum Toilet Forum discussions
    Last Post: 01-02-2011, 03:47 PM
  2. Replacing boiler with a gold series, good deal??
    By Gnfanatic in forum Boiler Forum
    Last Post: 07-22-2010, 03:46 AM
  3. Shopping for a boiler
    By frank6 in forum Boiler Forum
    Last Post: 01-19-2010, 03:14 AM
  4. What if a good deal might turn out to be stolen?
    By leejosepho in forum HVAC Heating & Cooling
    Last Post: 11-16-2007, 02:12 PM
  5. Shopping for a plumber
    By KathyER in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-08-2005, 05:21 PM
