Results 1 to 5 of 5
Thread: Best Water Softener Brands-Models for 800 Square Foot Cottage
    sea-bee chuck b's Avatar
    Jan 2011
    levering, michigan
    Default Best Water Softener Brands-Models for 800 Square Foot Cottage
    Planning water supply system for a Norther Michigan cottage that is seasonal, i.e. the water is drained from the plumbing supply system, water heater, etc. before the winter freezing temperatures.
    Wondering what type of Water Softener might be recommended. The cottage is not heated during the winter, if freezing temps would damage the unit in any way, e.g. freezing, electronics would need to know this.
    Also, should the water softener be installed between the sediment filter and the water heater or before. Thanks.
    Have no idea what I should be looking for feature wise, e.g. electronic timers, mechanical, etc. Also, does it reduce the water pressure from the well? Are the big box stores a good place to buy? Where else?
    Dec 2009
    Alaska
    Cheap is the box stores... and that is all that I will say on box store units
    There are Fleck units out there and most likely a day pattern would be better for you if water usage is going to be more of a hit and miss...
    There are ways of doing a system so that it can be blown down in the fall, I do it all the time and systems are ready to go again in the spring for many a customer.
    Well, pressure tank, sediment filter and then softener.. would be the way I would lay them out in the plumbing order..
    I vote no on the prefilter, unless the water is visibly dirty.
    Nov 2010
    Maine
    Whatever you decide on you can't let it freeze. You are going to want it installed with unions so that you can store it in a warm place for the winter. Draining the valve head alone won't stop damage and it's a bear to completely drain the resin tank, so make sure you can take the tank out and do not lay it down when you transport it either.
    DIY Member JKERN's Avatar
    Jan 2011
    Artesia NM
    How long do you spend at this cabin that can be a big determination in your needs all valves and equipment can be damaged by freezing temps what is your water makeup how many people are staying there on a regular basis and water usage is a lot more applicable than square footage when you have these answers it is a lot easier to answer your question
  1. Water system for rural cottage
    By gardner in forum Solar and Geothermal Water Heating Forum
    Last Post: 07-22-2011, 05:23 AM
  2. American Standard Brands rebadging same toilet under different brands...
    By MFfan310 in forum Toilet Forum discussions
    Last Post: 05-06-2010, 12:59 AM
  3. Cottage Water System Re-fit
    By csstechguy in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-12-2010, 09:30 AM
  4. Winterize lake water intake to cottage
    By lhartl in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-02-2009, 05:54 PM
  5. Water system for rural cottage
    By gardner in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-02-2007, 07:16 AM
