Thread: Heat pump clicks but doesn't run
    DIY Junior Member prepper's Avatar
    Jan 2011
    IN, USA
    Default Heat pump clicks but doesn't run
    From an earlier post I read this: "Have a helper set the thermostat up above the ambient indoor temp and you listen to the contactor. If it has 24v and does not click that is your problem."
    Mine is running fine indoors and when temp is low enough the auxillary heats like normal but when temp isn't low enough inside fan just runs and runs, heat pump unit outside clicks about every 10 secs but nothing else, no running, no hum, nothing.
    Know I can't troubleshoot and fix myself but any chance its just a relay or something?
    There may be a reset switch you could try pressing on the unit. Not much more to do unless you have some diagnostic tools and knowledge. A close visual check might turn up something. For example, one year, I had a mouse electrocute itself across my main a/c contactor sometime during the winter. When I tried to turn the a/c on in the spring, nothing...the fluids had gummed up the contactor and it was frozen solid. Some liberal use of contact cleaner, and all's well again without a service call.
    DIY Junior Member tempritespokane's Avatar
    May 2011
    Spokane
    I've found that the problem happens when the thermostat/heat pump wants to go into/out of Auxiliary heat mode. Is that the case for you?
    Mar 2011
    Houston, TX
    hello prepper, Welcome to Terry's Forums.
    You might want to check the Breaker for the outside unit.
    Many times the Inside and outside units are on different breakers.
    The 24 Volts come from the inside, sounds like that is working, and will click the outside relay,
    but the compressor could be on a different breaker/circuit, And may not be getting power.
    Have a great Day.
    DonL
    Don't pay someone to do a job fast, when you can do a half-fast job yourself.
  1. Emergency Heat vs heat pump in very cold weather
    By Mikey in forum HVAC Heating & Cooling
    Last Post: 03-03-2010, 05:54 PM
  2. Heat pump auxilary heat
    By Giles in forum Electrical Forum discussion & Blog
    Last Post: 02-11-2010, 11:03 AM
  3. Replies: 1
    Last Post: 02-04-2009, 11:59 AM
  4. Broken Heat Pump Liquid Return Line, Repair or Replace Heat Pump
    By lukekb in forum HVAC Heating & Cooling
    Last Post: 06-04-2007, 02:38 PM
  5. Water Source Heat Pump Deep Pump Sizing
    By Greg-VA in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-21-2007, 04:49 PM
