Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
Thread: Missing vent?
  1. #16
    Jun 2009
    Canada
    Quote Originally Posted by geniescience View Post
    Must know the total distance of the NEW 2" pipe, and its fall (drop, slope).
    Even if you do everything as said above, you can still cause a big problem. Best is to hire a Master Plumber. Next best is to leave it as is. Worst is to build something new, based upon a little bit of internet learning. If you want to go ahead and move the pipes around, you still need to answer the question in my first sentence, and a few other questions. Posting a very accurate drawing is best. Next best is posting a drawing showing distances.
    You're far from helpful...
  2. #17
    The Original Posting Person gets the service here. Helpful to newbies. The goal in this thread is to speak to he Original Posting Person, who has the problem.
    If you think you want to move the pipes around, changing the place where the Wye connects two drain branches or arms, you Must know the total distance of the proposed NEW pipes, and their fall (drop, slope). This is a helpful reminder. I mentioned the 2" pipe in my previous pipe because this is the one that is proposed to be longer than before.
    Some of the pieces of advice you received in earlier posts Do Not take this into account. To avoid causing a big problem, post an accurate drawing, or post again about distances.
    If another reader wants to know more, stay tuned and come back when this thread grows longer, or go read other threads about total developed length of DWV pipes.
    Hope this helps. This post reiterates my previous post. Hope you enjoyed the reminder.
  3. #18
    Jun 2009
    Canada
    You're not a plumber, are you?
  4. #19
    Jan 2008
    He is right in that the wet vent will not work if it is too long or not pitched properly.
  5. #20
    dlarrivee said to the original poster that if he moved his Wye downstream, to be sure the pipe would be 2" diameter and not 3", upstream of the new Wye.
    The thing is, one guy saying to another over the internet, just do this and that should work, isn't always going to be good advice, unless it gets checked and double-checked. Why not just let the "correcting party" have an easy time of it.
    Now, listen folks; when someone cuts in to say uh-oh, that's a good time to go silent and wait.
  6. #21
    Jun 2009
    Canada
    So you are a plumber now?
  7. #22
    Nov 2010
    Maine
    Depending on who's code you are under you may not need to vent the toilet. IPC lists toilet to vent distance as unlimited. Realistically, since a toilet is a self siphoning fixture, no vent is needed. The shower drain should be 2" not 1 1/2.
  1. hot water is missing
    By bumper in forum Shower & bathtub Forum & Blog
    Last Post: 01-14-2011, 08:33 AM
  2. missing bath/shower tub vent NEW install
    By novicepiper in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-16-2010, 07:49 AM
  3. Tub Stopper Missing
    By ShannonT in forum Shower & bathtub Forum & Blog
    Last Post: 01-28-2009, 02:58 PM
  4. Missing mortar bed for tub
    By lylec in forum Shower & bathtub Forum & Blog
    Last Post: 08-15-2008, 03:52 PM
  5. Missing reply?
    By got_nailed in forum Terry's Corner
    Last Post: 03-27-2008, 10:00 AM
