Page 1 of 2 12 LastLast
Results 1 to 15 of 22
Thread: Missing vent?
    DIY Junior Member jbg's Avatar
    Jan 2011
    Northern VA
    Default Missing vent?
    Hey Folks-
    Great Forum. This weekend I went to move a 2nd floor toilet 6 ft from existing spot to create an alcove for it. I opened up some of the first floor ceiling to see what I was up against. Below is what I found. Toilet is direct to 3" soil stack. The tub and shower have branch drains to the 3" soil stack which runs down the front wall of the house. Tub and shower are vented to vent stack at back corner of house. First question is, am I missing a vent for the toilet? If so, any ideas how to easily fix this?
    missing vent.pdf
    Jan 2008
    One would need to know where and how the lavatory is attached to the system to say for sure. Many areas allow the WC to be vented through the lav.
    Jan 2011
    Northern VA
    Thank you cacher. The 3" waste pipe starts at the 2nd floor toilet via two 45 degree angles from the toilet, then travels 8 ft horizontally, then 90 degree turn and straight down to the slab. If the Shower and tub branch drains didn't connect to the 3" waste pipe during the horizontal run, it would be a dedicated waste pipe for the toilet only. Nothing else hooks into it below or above it. Seems like the branch waste drain is the only vent for the toilet.
    Jan 2008
    As you have drawn it, the toilet line can pull air through the tub and shower vents, but this is not a proper vent for the toilet.
    Jan 2011
    Northern VA
    Thanks Cacher. I misspoke. After a few more openings in the ceiling one of the branches is not from the shower but the sink. So it looks like the attached. I think this is OK but not great. If I move the toilet drain to the other side of the 3" soil stack but within 3ft of the branch drain/vent am I still OK?
    Jun 2009
    Canada
    I don't see much wrong with your latest drawing, seems common to me.
    Jan 2008
    What you have now drawn is what I would have expected to see.
    Not clear on where the toilet is being moved to, but it has to be upstream of the 2" coming off the lav or your vent will be broken.
    As long as the "vent" is being "washed" by the lav or shower/tub the orientation of the toilet is immaterial. "Moving the toilet 6 feet" however COULD be a problem.
    Jan 2011
    Northern VA
    Thanks Everyone. I wasn't as clear as I should have been. In that last drawing, I wanted to move the toilet to 3 ft on the other side of where that branch drain comes in. If that causes a vent issue, I guess I could move the toilet and the extend that branch drain a few more feet to come in down stream of the toilet. Would that work better?Name:  Vent.bmp
    Jan 2008
    You need to find out what the maximum allowed distance is between the WC and it's vent.
    Should not have any 3" upstream of the WC. The tub and/or lav will not be able to clean the 3" line.
    Jun 2009
    Canada
    Although I agree there shouldn't be 3" upstream of the w/c... I don't see it causing a huge problem, what exactly needs "washing" upstream of the w/c?
    Jan 2011
    Northern VA
    I'll look to see if I can move the branch downstream of the WC. Thank you very much for you help on this
    Jun 2009
    Canada
    Quote Originally Posted by jbg View Post
    That isn't what we are getting at... you've mistaken something there.
    The piping only needs to be 3" downstream of the w/c, leave your drawing the same but make sure you use 2" upstream of the wye where your w/c ties in.
    Jan 2011
    Northern VA
    Ah. Great. That makes my life a lot easier. I really appreciate the help.
    Nov 2005
    Must know the total distance of the NEW 2" pipe, and its fall (drop, slope).
    Even if you do everything as said above, you can still cause a big problem. Best is to hire a Master Plumber. Next best is to leave it as is. Worst is to build something new, based upon a little bit of internet learning. If you want to go ahead and move the pipes around, you still need to answer the question in my first sentence, and a few other questions. Posting a very accurate drawing is best. Next best is posting a drawing showing distances.
  1. hot water is missing
    By bumper in forum Shower & bathtub Forum & Blog
    Last Post: 01-14-2011, 08:33 AM
  2. missing bath/shower tub vent NEW install
    By novicepiper in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-16-2010, 07:49 AM
  3. Tub Stopper Missing
    By ShannonT in forum Shower & bathtub Forum & Blog
    Last Post: 01-28-2009, 02:58 PM
  4. Missing mortar bed for tub
    By lylec in forum Shower & bathtub Forum & Blog
    Last Post: 08-15-2008, 03:52 PM
  5. Missing reply?
    By got_nailed in forum Terry's Corner
    Last Post: 03-27-2008, 10:00 AM
