Results 1 to 7 of 7
Thread: Instant hot??????????
    DIY Member bsa_bob's Avatar
    Jan 2011
    britton mich
    Question Instant hot??????????
    My house is very long, and we are tired of wasting over a gallon of water ,waiting for hot water in the kitchen. I need to know which make of "instant hot"is the best way to go. I can handle it so throw it out there at me. I am still a licensed plumber in michigan.
    I am retired though--and am asking, as things change alot from year to year. please feel free to share what you have for me and thank you guys bob s
    PS i'm in the market for one i can install in the line and maybe mount it below the kitchen floor............ in the basement
    Yakima WA
    I believe the best recirculation system is one that uses a return line. However, as a plumber you realize that retro fitting a return line might be very difficult. There are devices that do not require the return line so one of these might be your best option. There are several good brands available. Laing is one that I have experience with and they have a web site that describes their different models and have installation diagrams for them.
    The wear part on many is the cross-over valve that you use if you don't have a dedicated return line. While po-poo'ed by some, I've had good luck with my Redy-Temp unit...very simple to install, but it needs an outlet under the sink you choose to install it in. Takes all of about 10-minutes with only a pair of pliers or a wrench to relocate some faucet supply hoses. Since I've had mine, they've added several different models, so I do not know about all of them.
    Jan 2009
    Try not to simply trade wasting a gallon of water with wasting fuel with the recirc. Those that are "always ready" abandon a significant amount of heat in both the supply and return lines. Those that only crank up the pump when flow is detected, or those that require the user to call hot water by hitting a button waste far less heat than simply thermostatic versions.
    Insulating the supply line with 5/8" or 3/4" wall pipe insulation increases the time between calls that would require the recirc pump substantially, thereby reducing the net abandoned hot water volume. Even the cheap 3/8" walled R2 stuff like that available at box stores is better than nothing.
    Nov 2005
    Insta Hot = anaheim.
    http://www.anaheimmfg.com/
    It's a mini tank.
    no wasted water.
    If you are only interested in one location getting the hot water 'immediately', then a small electric tank fed from the hot line would also work. By the time the tank was depleted, hot would be available to mix in (feed it from the hot line) and the temp would only vary slightly if sized properly. This would take more space than a recirculation system and probably more energy. To save some money, as mentioned, insulate the lines and consider using either a timer or demand switch...with a demand switch, you'd still have to wait, but would still save water...it would just recirculate - you'd have to wait for the hot to get there.
    Jan 2011
    britton mich
    Some good choices...And i know what to look into. thanks for the genuine help guys bob s
  1. Instant hot water
    By WV Hillbilly in forum Plumbing Forum Discussion & Blog
    Last Post: 12-16-2008, 05:12 AM
  2. Instant On HW and Shut Off Valves
    By joe in queens in forum Plumbing Forum Discussion & Blog
    Last Post: 01-09-2007, 10:09 PM
  3. Instant hot water everywhere BUT the kitchen
    By gotpeter in forum Plumbing Forum Discussion & Blog
    Last Post: 05-27-2005, 07:40 PM
  4. Instant hot water heaters
    By Jim Hesser in forum Plumbing Forum Discussion & Blog
    Last Post: 03-20-2005, 02:23 PM
  5. Instant Water Heaters
    By Kelly in forum Plumbing Forum Discussion & Blog
    Last Post: 09-20-2004, 05:24 PM
