Thread: T-wye or Sani-t on 3" secondary stack
    DIY Junior Member
    Jan 2011
    Pittsburgh, pa
    Default T-wye or Sani-t on 3" secondary stack
    Hi-
    What is the correct piece to use on a 3" vertical secondary stack. I am adding in the plumbing from my washer to this. it currently has a cleanout T on it, which will be moved up to make room for this. i would prefer to use the Sani-t since it will add less height to the plumbing but can make the T-wye work.
    You can use a santee on the vertical. Just make sure you vent the washer between the stack and the p-trap.
    DIY Junior Member
    Jan 2011
    Pittsburgh, pa
    Yep. I believe the vent needs to be less that 60" from the p-trap to the vent correct?
    I know that AAV's are hotly contested. i was thinking about using one in the application, and coult *possibly* get it routed to the outside. Any throughts on this?
  1. Tying 4"x4"x2" all-hub into existing stack
    By Ed_S in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-11-2007, 03:22 PM
  2. secondary vent stack ending in attic
    By chuck_r in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-23-2006, 12:34 PM
  3. Make chrome trap to sani-T connection look nice
    By jwray in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-22-2005, 06:52 AM
  4. secondary stack
    By jeffrey in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-10-2004, 10:34 AM
  5. "undoing" joint in abs plumbing stack?
    By tgunn in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-12-2004, 01:32 AM
