Results 1 to 5 of 5
Thread: What determines hose bibb size?
    DIY Senior Member DavidTu's Avatar
    Dec 2009
    Seattle, WA
    Default What determines hose bibb size?
    For 2x4 walls with wood siding what determines the appropriate 3/4" tube length for a vacuum breaker non-freezing hose Bibb?
    Mine are 12" long, and that works just find in Yakima which sees colder temperatures than you get in Seattle, so that should be ample length for you. I really don't know if there are different lengths, all you really have to do is get them through the wall with enough length to work with inside. Main thing is to be sure you remove the hose in the fall before frost season. I have recently heard there are some that will drain even with the hose connected, but I haven't actually seen them so I can confirm or deny their effectiveness.
    The determining factor is "how long does it have to be so the operating section is in a warm area".
    Normally six inches for 2x4 and eight inches for 2x6
    Or longer always works too.
    Woodford makes some self-draining frost-free faucets. Here is one of them: http://www.woodfordmfg.com/woodford/.../30Catalog.pdf
  1. What determines waterflow from underneath rim?
    By truffles in forum Toilet Forum discussions
    Last Post: 09-27-2009, 12:46 PM
  2. Hose Bibb Connected to Underground Sprinker System
    By c_g_lima in forum Irrigation / Sprinkler Forum
    Last Post: 09-21-2009, 08:01 AM
  3. What's the thing called on a freeze proof hose bibb?
    By Melissa2007B in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-16-2007, 09:39 PM
  4. Frost-proof hose bibb - threaded?
    By garyl53 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-04-2007, 03:57 AM
  5. Woodford 17 Anti-Siphon Hose Bibb
    By mwaldon in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-20-2005, 12:28 PM
