Results 1 to 5 of 5
Thread: Clogged toilet help
    DIY Junior Member juajuslee's Avatar
    Jan 2011
    Burnaby, BC
    Default Clogged toilet help
    Hi
    i need help with my clogged toilet but there is a big problem.
    someone put plastic wrappers in it and now it only slowly sucks water in.i tried the toilet toilet plunger but it doesn't work.
    Any help please?
    You may need a toilet auger, or pull the toilet and fish them out if that doesn't work.
    Jan 2011
    Burnaby, BC
    can it work in a apartment?
    Plumbing is a home is the same as in an apartment.
    If you have plastic stuck in the trapway, you will need to pull it out.
    It would make sense to pull the bowl, and use the closet auger from the bottom to push it back into the bowl.
    Pushing it down into the drain may not be a good idea. Right now you only have a plugged toilet.
    A toilet auger is a hand tool. Some work better than others.
  1. Toilet Clogged
    By Rickcusaf in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-25-2010, 07:17 AM
  2. Replies: 9
    Last Post: 06-30-2010, 01:13 AM
  3. clogged toilet
    By lauriebee in forum Toilet Forum discussions
    Last Post: 10-05-2009, 10:05 PM
  4. clogged toilet
    By greggo in forum Toilet Forum discussions
    Last Post: 08-31-2007, 02:35 PM
  5. Clogged up toilet
    By Toilet_dude in forum Toilet Forum discussions
    Last Post: 06-16-2006, 07:02 AM
