Results 1 to 4 of 4
Thread: laundry drain size?
    DIY Member rick.a's Avatar
    Jan 2007
    Palmer, Massachusetts
    Default laundry drain size?
    I am installing a clothes washer as part of a bathroom remodel and want to connect it to a drywell that is technically illegal in MA but allowed since it is preexisting, and grandfathered in. The problem is that the drain pipe in the basement that goes to the dry well is 1 1/2 in. I know that 2" is code for washers, but since this will not be inspected, do you think that it will drain OK? I am assuming that it will cause the previous owner used it. I located the well and it is only about 6 ft from the outside of the foundation so the run is short. Washer will be a small stackable front loader.
    thanks,
    Rick A.
    Jan 2008
    If it will work depends completely on the pumping capacity of the washer. If I had to do such a thing, I would pump the water into a laundry sink which only requires a 1-1/2 drain.
    The reason the code is 2" is because many washers will pump out faster than a 1-1/2" standpipe can drain.
    It is grandfathered only if it was legal in the first place AND you do nothing to change it.
    Nov 2005
    it will work. Your FL is what nails it.
    The Canadian code never got around to increasing from 1.5" to 2", and all washers sold in the US are legal for sale in Canada. Hint hint. I think the increase to 2" size was good for builders; it allowed them to build bigger houses without worrying about venting as much.
    FL washers produce less water, in any case.
    Jan 2007
    We don't have space for a laundry sink so I will need to just hook it up in order to try it. But since 1.5 used to be the code and modern washers use LESS water, I now only worry that the RATE that the new
    front loader machines pump out the water might be a problem.
    Do you think that using a 2" standpipe and trap , then reducing to my 1.5 where it exits the building might give me a little more pipe water holding capacity and be better than using 1.5 all the way??
    Rick A.
  1. Laundry tub draining into basement floor drain - open pipe into drain hole
    By scott.oneill in forum Plumbing Forum Discussion & Blog
    Last Post: 10-24-2010, 02:20 PM
  2. Adding Laundry Room Drain to Kitchen Drain
    By lukus in forum Plumbing Forum Discussion & Blog
    Last Post: 05-20-2008, 01:15 PM
  3. Laundry Tub Drain Help
    By statjunk in forum Plumbing Forum Discussion & Blog
    Last Post: 09-08-2007, 08:27 AM
  4. New shower drain into existing laundry drain?
    By jsr in forum Shower & bathtub Forum & Blog
    Last Post: 07-31-2007, 06:10 PM
  5. Laundry drain conundrum - drain CWM into bathtub?
    By vga4life in forum Plumbing Forum Discussion & Blog
    Last Post: 04-29-2006, 06:43 AM
