Thread: Shower valves run hot only in the last few degrees of rotation
    DIY Junior Member
    Jan 2011
    Raleigh, NC
    Default Shower valves run hot only in the last few degrees of rotation
    In my house, I have 6 shower/tub valves, all about 15 years old. Each valve, including the kitchen faucet, only gets hot water in the last few (3-5) degrees of handle rotation before full hot. Once hot water is running, moving the handle only a few degrees off full hot gets cold water. Any ideas anybody?
    My theory is there must be a big pressure differential between hot and cold, so that it takes calling for lots of hot water to overcome the cold. However, hot and cold water flow seems about the same.
    Mark
    Jan 2008
    And you have a tankless water heater?
    DIY Junior Member
    Jan 2011
    Raleigh, NC
    No, conventional gas, set to about 120 or 130.
  1. price pfister shower installed at 90 degrees
    By lach_v in forum Plumbing Forum Discussion & Blog
    Last Post: 08-24-2009, 07:22 AM
  2. Flange rotated about 5-10 degrees
    By dzarn in forum Toilet Forum discussions
    Last Post: 11-03-2008, 05:27 AM
  3. Turn Shower Mixer 90 degrees - OK?
    By dpsinghx in forum Plumbing Forum Discussion & Blog
    Last Post: 01-29-2007, 06:56 PM
  4. Turn a toilet 90-degrees
    By jadnashua in forum Toilet Forum discussions
    Last Post: 11-28-2006, 04:49 AM
  5. DWV hub at 60 degrees
    By concretehouse in forum Plumbing Forum Discussion & Blog
    Last Post: 08-01-2006, 07:14 PM
