Originally Posted by
Akpsdvan
Brass body with the in at the back and out at the top, body looks be one piece?
In any event the brine injector block on top of the valve body is the place to start looking and cleaning.
If you have not down loaded the 1500 or 2510 book , do so..
Under the metal cap is the injector that can plug, a small paper clip straightend will work to clean out the injector and then make sure that the screen is clean.
Let us know if that works , pm is you need to ... other wise the fleck book should be able to walk you through most challenges with the valve.
