Results 1 to 4 of 4
Thread: Ariens 824
Hybrid View
    DIY Member Barry J's Avatar
    Mar 2007
    Mass
    Default Ariens 824
    I have an Ariens 824 snowblower, that the drive gear doesn't seem to be acting right. I do not seem to be able to go thru snow like I use to. I've adjusted the cable, and we had some heavy snow yesterday and I've noticed that I had to push more than usual. And when I got done snowblowing, I was going toward my shed with the snow blower and I noticed black spots coming from under the rear casing. The snow blower seems to be moving fine, just when there is a heavy load it seems to have touble. Now, I don't know if the black drips was just water splashing up inside the case and some oil being mixed with it and dripping down or if I have a problem.
    I did not take the cover off the case, because I don't know which way to tip the machine. Also, wouldn't know what to look for.
    I don't want to bring it to the repair shop, in case nothing was wrong...he seems to keep the machines longer than needed, and pretty much has the attitude of "it's done, when it's done."
    I can't be without my snowblower for weeks.
    Any suggestions
    Barry
    Mar 2007
    Mass
    Here are some pictures I took with the bottom plate down
    Yakima WA
    If it was mine, it would be off to the dealer/repair shop before the next snow storm. Maybe you feel comfortable tearing into it, but while I'm not totally inept at mechanical things, I would just as soon have the guys with experience deal with it. I do understand about shops that take there own sweet time. Maybe you could find another shop that offer better service.
    DIY Junior Member Diskman's Avatar
    Feb 2011
    White Lake, MI
    I have the same model, about a year ago I had to replace the friction disc and found the same thing inside. Check the link below.
    http://www.jackssmallengines.com/ari...ctiondiscs.cfm
