Results 1 to 2 of 2
Thread: Need help to remove Kohler tub's lift and turn drain stopper
    DIY Junior Member diynewbie's Avatar
    Jan 2011
    Minnesota
    Angry Need help to remove Kohler tub's lift and turn drain stopper
    I am struggling to remove the set-secrew to de-clog the drain. The set screw seems to be a brass one and easily stripps off when trying to unscrew using any regular screw drivers.. I would appreciate any advice to remove the stopper and de-clog the drain and I would like to replace the screw with a stainless steel one so that it doesn't strip in the future .. The space is so narrow (about 1/4") between the tub floor and the lifted drain that even inserting a screw driver is a PIB (pain in the b..t).. .. Please help..
    Jan 2011
    Minnesota
    Default found my answer
    whether the lift-and-turn stopper has a setscrew or not , push the stopper down as if you close the tub from draining any water. Then use your plier or wrench turn the head of the stopper counter-clockwise. This unscrewed the whole assembley instead of just opening the stopper head.... Hope this might save ton of time and aggrevation for another newbie like me!!
  1. Help with Kohler lift and turn tub drain
    By chasgynonc in forum Shower & bathtub Forum & Blog
    Last Post: 11-18-2011, 09:08 AM
  2. Lift and Turn Tub Drain
    By jdizzle3id in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-15-2009, 07:37 AM
  3. lift and turn drain removal
    By missfixit in forum Shower & bathtub Forum & Blog
    Last Post: 05-02-2008, 12:49 PM
  4. Tub lift-and-turn stopper problem
    By lloyd.116 in forum Shower & bathtub Forum & Blog
    Last Post: 06-20-2006, 08:18 AM
  5. Old Crane bathtub stopper - HOW to remove it?
    By ps400 in forum Shower & bathtub Forum & Blog
    Last Post: 01-16-2005, 04:05 PM
