Results 1 to 8 of 8
Thread: voltage drop
    DIY Member ugabulldog's Avatar
    Nov 2007
    Northeast GA
    Default voltage drop
    Voltage drop was calculated for #10 wire and I am very close (right at) to the max run so I think I will need to size down to #8 wire running 390 ft. to well,....wire in well is 240' of #10 wire, is this ok to mix 8 & 10 to compensate for volt drop?
    Moderator valveman's Avatar
    Mar 2006
    Lubbock, Texas
    Actually having the maximum recommended cable length is a good thing. It makes a natural soft starter. #10 wire will go 630' with a 1 HP motor. It doesn't hurt anything to start with #8, except that it won't give you the soft start like 630' of #10 will do.
    "Reduced-voltage starters may not be required if the maximum recommended cable length is used. With maximum recommended cable length there is a 5% voltage drop in the cable at running amps, resulting in about 20% reduction in starting current and about 36% reduction in starting torque compared to having rated voltage at the motor. This may be enough reduction in starting current so that reduced-voltage starters are not required."
    Heres the link;
    http://www.franklin-electric.com/aim...l/page-36.aspx
    Dec 2009
    northfork, california
    I have almost the exact same setup and pump is happy for several years and runs on 239 volts after start up. I may even have a 1.5hp motor on it.
    But where is the control box? at the beginning of the run, or at the well head?
    Mar 2006
    Lubbock, Texas
    I don't think it will make much difference where the control box is. But I think the starting torque would be less the further away the control box is.
    Nov 2007
    Northeast GA
    Quote Originally Posted by valveman View Post
    Heres the link;
    That is my problem,...I am a little over 630', by a few feet, so I should go with #8, in fear of burning pump up faster, correct?
    Dec 2009
    You can mix wire sizes. But the charts have much leeway in them. Dont sweat a few feet.
    Nov 2007
    Northeast GA
    control box is at the well head, does this make a differnce ballvalve or anyone??
    Well Drilling/Service justwater's Avatar
    May 2010
    NE FL, SE GA
    it's fine, no worries.
  1. Wall Socket With Voltage AND No Voltage? HELP!
    By jackvogel in forum Electrical Forum discussion & Blog
    Last Post: 12-23-2010, 07:41 AM
  2. Service entrance cable size & voltage drop
    By curtherrin in forum Electrical Forum discussion & Blog
    Last Post: 08-24-2009, 12:47 PM
  3. Running low voltage in high voltage boxes
    By Ian Gills in forum Electrical Forum discussion & Blog
    Last Post: 08-22-2009, 07:27 PM
  4. Lights flicker and Voltage Drop Question
    By Pip in forum Electrical Forum discussion & Blog
    Last Post: 12-18-2008, 06:25 PM
  5. Getting zapped by DC Voltage
    By speedbump in forum Electrical Forum discussion & Blog
    Last Post: 01-04-2008, 10:58 AM
