Results 1 to 9 of 9
Thread: blower motor size
    DIY Junior Member mark floyd's Avatar
    Jan 2011
    new jersey
    Default blower motor size
    how can i determine the proper size blower motor on an oil furnace? i have a magic chef L6284D3 serial #16087KAB 84000btu output. the blower motor has obviously been replaced by a single speed motor and there is a label indicating a motor wired for low and high speed. lots of questions ,rpms,hp, amps etc. thank you
    Dec 2009
    northfork, california
    type those numbers into google + spec's
    Jan 2011
    new jersey
    if that would have worked i would not be here asking you fine people for help. oil service guys won't give me any information either. all i want to do is change an apparent hack job or emergency fix to the right motor. don't know if the specs on the current motor are good to use. thankyou
    Plumber jimbo's Avatar
    Only a service dealer for that brand ( I don't know who makes Magic Chef HVAC) would have access to a parts and service manual for an old furnace. If Google Manuals doesn't have it, you might need to look for a dealer.
    Dec 2009
    If its working ok, why mess with it? Running it high speed cannot hurt anything, probably increases the efficiency anyway.
    Must be very old if magic chef was making oil furnaces!
    Jan 2011
    new jersey
    escuse me but obviously it is NOT working ok if i had to open it up and SEE that it is NOT THE CORRECT motor for the application. it was noisy and i found the squirrel cage loose and the motor shaft also seems too loose like the bearing is starting to go. slight oil seepage also. motor diameter seems too small for the mounting band also. yea it's been working 'til now but i expect trouble soon and i want to get the RIGHT MOTOR! gee wiz i was hoping to get help here.
    Nov 2009
    VA
    I assume it is a direct drive motor (motor directly attached to blower wheel). I know Grainger carries a wide selection of blower motors, but from what I have seen, they have the motor (by itself) without the blower connected.
    Anyway, you are probably looking for something in the 1/2 HP - 3/4 HP range. If you look at your current motor, what specs are on the label?
    I can check my blower motor for you. It is an older one, but my electric furnance is also ~80k BTU and the speed is set to med-high for heat and high for AC (I believe).
    You probably are looking at something in the 1200 CFM range for flow. With a multi-speed (or variable speed) you can slow it down to get the delta-T across the furnance that you are shooting for.
    Quote Originally Posted by mark floyd View Post
    By asking a dealer or authorized factory service technician. We have tried to make that point. No one has a genie in a lamp that can just poop out a motor spec for you , sight unseen. How old is that furnace? Is it even worth spending money on a new motor??
    DIY Member m3rdpwr's Avatar
    Dec 2008
    Massachusetts
    When I had to replace the motor for my 40 year old Janitrol, no one could cross refference the motor anywhere.
    Than for the hell of it when I was handed the wrong motor and Grainger and told them it was wrong, they looked up my old motor again, but left off the last digit.
    Bingo! They found the exact replacement.
    Try searching by leaving off the last digit of part number.
  1. Snow Blower
    By Gary Swart in forum Lawn Care/Landscaping
    Last Post: 12-22-2010, 08:04 PM
  2. Blower motor not kicking on???
    By walds11 in forum HVAC Heating & Cooling
    Last Post: 04-11-2010, 08:23 AM
  3. Cast iron motor adpater cracked Goulds Motor Apapter Part#1K310
    By on02151blueline in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-18-2010, 04:56 PM
  4. Why would the blower keep running?
    By parineetha in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-27-2009, 11:55 PM
  5. Is a GE 5-wire blower motor speed-controlled?
    By leejosepho in forum HVAC Heating & Cooling
    Last Post: 02-23-2007, 02:46 PM
