You have to be able to remove and service the pump through the access opening, regardless of where it is located. Some manufacturers will relocate the pump to the area where your access opening will work, but it appears that one of the two locations should work for you if you select the proper one..
The plan has the end of the tube backing a steam shower. I've emailed Aquatic but they've been unresponsive.
