If you intend to test it and then remove it, you will compromise your test. If you just want to check its mechanics, test it BEFORE you set it in place, the do the actual installation after you are done.
Hi folks. Installing a new american standard whirlpool tub in and alcove configuration (where only one side will be open). I want to set the tub/drain prior but was wondering if I test it first, then disconnect, pull it out of the alcove and then install it with a setting bed?
What's the best setting bed for this type of set-up. The underside of the tub is wood covered fiberglass with two support runners.
Thanks in advance.
If you want to test the exterior connections, do it outside on the lawn. Plug the drain and fill with a garden hose.
Then carry it back inside, and then worry about banging the connections you just tested when you install it for real.
They test those things at the factory before they crate them.
Terry wont it be heavy with all that water in it?
Good advice - I never thought to do this test outside before....
JW
"When it's Perfect. It's good Enough." - John Whipple ...................... Q: Who are the Top Ten Bathroom Designers for 2010-2012..? ANSWER
Contact Info: Email jfrwhipple@gmail.com Phone: 604 506 6792 Alternate Email: info@byanydesign.com
That is why you do it outside so the lawn gets watered when you pull the plug.
This is turning into a "Green Building" thread... I love it.
So many builders and plumbers just don't think about that wasted 60 gallons of water.
