dbol
I was wondering how I should go about running my drain line? I was planning on using a plumbing outlet box for my drain but I am not sure that will work to well. I am planning on putting my washer on the left and sink tub to the right.
I want it to look neat and not just run the washer drain into the tub.
If I run the drain in between the studs and in to basement where does the trap go? Or I can run it through the wall into the basement. About 18 inches off the floor I can drill a hole and run my drain there.
