Results 1 to 4 of 4
Thread: Simple Question 5600 Econominder
    DIY Junior Member gizzy's Avatar
    Jan 2011
    Michigan
    Default Simple Question 5600 Econominder
    My softener runs every 5-6 days. It needs to run every 2-3 days. If I manually regenerate, everything is fine. How do I get it to run more often?
    The manufacturer website is very vague on this. Help!
    -gizzy
    Dec 2009
    Alaska
    Is it a meter or day?
    In the lower right hand corner is either a 12 day wheel or a wheel that goes from 0-21 that is a gallon counter..
    DIY Member JKERN's Avatar
    Jan 2011
    Artesia NM
    I would guess that yours is a metered since econominder is generally referring to the metered 5600. Trick your unit by turning the capacity down. You need to figure out your gallonage usage first and then turn it to whatever that usage is in 2-3 days. On the other hand is that if this unit was set correctly for your water makeup and usage this is probably an indication that something is not working. How old is your unit and are you sure it was set properly at the initial startup?
    If there is nothing wrong causing hard water breakthrough before regeneration, you can click the link in my signature to learn how to determine when it should regenerate.
  1. Fleck 5600 Econominder
    By brew24 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 05-26-2011, 09:14 PM
  2. Fleck 5600 vs. 2510, Econominder vs. SXT
    By borisgoodenough in forum Water Softener Forum, problems, installation and reviews
    Last Post: 01-14-2011, 12:14 PM
  3. Simple question
    By eod4647 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-27-2009, 12:04 PM
  4. a simple question
    By jwelectric in forum Electrical Forum discussion & Blog
    Last Post: 12-08-2008, 02:21 PM
  5. Flack 5600 question
    By Sprink669 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-05-2008, 11:32 AM
