Results 1 to 4 of 4
Thread: Fleck 9100 Timer ID
    F5Scott sarrowsm's Avatar
    Dec 2010
    Brighton, MI
    Default Fleck 9100 Timer ID
    Please help ID this Fleck Timer on 9100 Control Valve?
    Thank you,
    Scott
    Dec 2009
    Alaska
    It is the 3200 timer run from Fleck, the one that you have does not have time, but rather gallons to trip it from one tank to the next.
    The frame that the parts are on is the same frame that is used for the timer one that will delay in gallon or day time trip..
    Set the gallons across from the white dot much like your old one.. if your old one was at 800 gallons then find the 8 on this one and set with the white dot..
    DIY Junior Member Old Fart's Avatar
    Jan 2011
    Mi
    Pentair makes Fleck and Autotrol valves. PentairWaterTreatment.com, click on Fleck control valves. On the right side of the page, under Residential, is a list of Fleck & Autotrol valves. Click on a model number and it takes you to the spec sheets and the service manuals.
    I have about worn this sit out over the last week or two. Hope this helps.
    Dec 2010
    Brighton, MI
    Thanks for the help!
  1. Fleck 9100 Useage Mete Problem
    By Gerrylc in forum Water Softener Forum, problems, installation and reviews
    Last Post: 12-28-2010, 07:12 AM
  2. Had Fleck 9100 installed last January and my water is still brown
    By coxdrum48 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 07-23-2010, 10:40 AM
  3. Fleck 9100 and well gpm questions
    By boudreaux in forum Water Softener Forum, problems, installation and reviews
    Last Post: 07-08-2010, 07:54 PM
  4. Fleck 9100 Metered Twin Tank Water Softener - 24,000 Grain
    By bluinc in forum Water Softener Forum, problems, installation and reviews
    Last Post: 12-12-2009, 02:55 PM
  5. Hydrotek 1114 timer quit/installing RB timer help!
    By vics44 in forum Irrigation / Sprinkler Forum
    Last Post: 02-21-2008, 05:40 AM
