It is the 3200 timer run from Fleck, the one that you have does not have time, but rather gallons to trip it from one tank to the next.
The frame that the parts are on is the same frame that is used for the timer one that will delay in gallon or day time trip..
Set the gallons across from the white dot much like your old one.. if your old one was at 800 gallons then find the 8 on this one and set with the white dot..
